メインコンテンツにスキップ
Replacing Spring in Refrigerator Door
必要な工具と部品
  1. Replacing Spring in Refrigerator Door, Spring: 手順 1、 1の画像 1
    • Turn off the refrigerator by unplugging it or turning the breaker off.
    • There are electrical cords attaching the assembly flap to the door, so it is better to be safe.
  2. Replacing Spring in Refrigerator Door: 手順 2、 2の画像 1 Replacing Spring in Refrigerator Door: 手順 2、 2の画像 2
    • With a Phillips screwdriver, unscrew and remove the two screws on the hinge located directly in the middle of the door, connecting the assembly flap to the door.
  3. Replacing Spring in Refrigerator Door: 手順 3、 2の画像 1 Replacing Spring in Refrigerator Door: 手順 3、 2の画像 2
    • Located at the bottom of the assembly flap, remove the bottom plastic piece by gently shimmying it out with a small flat head screwdriver.
    • This may be a bit difficult.
  4. Replacing Spring in Refrigerator Door: 手順 4、 2の画像 1 Replacing Spring in Refrigerator Door: 手順 4、 2の画像 2
    • Carefully lift the assembly flap upward guiding it along the top and bottom plastic hinge just before it comes off.
  5. Replacing Spring in Refrigerator Door: 手順 5、 3の画像 1 Replacing Spring in Refrigerator Door: 手順 5、 3の画像 2 Replacing Spring in Refrigerator Door: 手順 5、 3の画像 3
    • On the bottom of the assembly flap, carefully insert the spring into the plastic holes. One is connected to the bottom plastic hinge and the other is attached to the assembly flap.
    • Slide the assembly flap down into place. Be sure the top and bottom plastic hinge slides into place. You’ll notice the spring securely sliding into the plastic holes.
  6. Replacing Spring in Refrigerator Door: 手順 6、 2の画像 1 Replacing Spring in Refrigerator Door: 手順 6、 2の画像 2
    • Re-insert the bottom plastic piece by pressing it in until it snaps.
  7. Replacing Spring in Refrigerator Door: 手順 7、 3の画像 1 Replacing Spring in Refrigerator Door: 手順 7、 3の画像 2 Replacing Spring in Refrigerator Door: 手順 7、 3の画像 3
    • Replace the two screws on the middle, metal hinge.
    • Turn the power on. Fast Fix is complete.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Christine Meyers
メンバー登録日: 01/15/18
271 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018人のメンバー
USFSM-STEWART-S18S1G1
15 メンバー
31のガイドは作成済み
1件のガイドコメント
Very helpful! Easily completed and solved my problem.
Stephen Joncus - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 127
今までの合計 15,580
