メインコンテンツにスキップ
Replacing Sonos Play 1 Power and Volume switch board.
必要な工具と部品
  1. Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: 手順 1、 2の画像 1 Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: 手順 1、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Replacing Sonos Play 1 Power and Volume switch board.: 手順 2、 2の画像 1 Replacing Sonos Play 1 Power and Volume switch board.: 手順 2、 2の画像 2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Replacing Sonos Play 1 Power and Volume switch board.: 手順 3、 2の画像 1 Replacing Sonos Play 1 Power and Volume switch board.: 手順 3、 2の画像 2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Replacing Sonos Play 1 Power and Volume switch board.: 手順 4、 2の画像 1 Replacing Sonos Play 1 Power and Volume switch board.: 手順 4、 2の画像 2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Replacing Sonos Play 1 Power and Volume switch board.: 手順 5、 1の画像 1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Replacing Sonos Play 1 Power and Volume switch board., Sonos Play 1 Top Cover Disassembly: 手順 6、 1の画像 1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Replacing Sonos Play 1 Power and Volume switch board.: 手順 7、 3の画像 1 Replacing Sonos Play 1 Power and Volume switch board.: 手順 7、 3の画像 2 Replacing Sonos Play 1 Power and Volume switch board.: 手順 7、 3の画像 3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Replacing Sonos Play 1 Power and Volume switch board.: 手順 8、 2の画像 1 Replacing Sonos Play 1 Power and Volume switch board.: 手順 8、 2の画像 2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Replacing Sonos Play 1 Power and Volume switch board., Power and Volume Switch Board: 手順 9、 1の画像 1
    • Using a screwdriver with a Torx T6 bit, remove the four highlighted 7mm screws.
    • Using you fingers remove the protective plastic plate covering the device.
  10. Replacing Sonos Play 1 Power and Volume switch board.: 手順 10、 2の画像 1 Replacing Sonos Play 1 Power and Volume switch board.: 手順 10、 2の画像 2
    • Using your fingers remove the plastic cover plate securing the switchboard.
    • Using your fingers, remove the power/volume switch board.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Patty
メンバー登録日: 09/01/15
465 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 8-4, Eyestone Fall 2015 USF Tampa, Team 8-4, Eyestone Fall 2015人のメンバー
USFT-EYESTONE-F15S8G4
4 メンバー
16のガイドは作成済み
9 件のコメント
Where can I get the replacement power button?
Teresa Rosales - 返信
I would like to know as well
hung pham - 返信
Dear Patty
Where can I buy the switchboard?
Thanks in advance. :-)
/Kenneth
Kenneth - 返信
Same quesion here from DK
Lars Jürgensen - 返信
where can i find board
craigmdyer - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 84
今までの合計 8,853
