メインコンテンツにスキップ
Replacing Oster 6329 Bread Lift Shelf
必要な工具と部品
  1. Replacing Oster 6329 Bread Lift Shelf, Outer Shell Removal: 手順 1、 2の画像 1 Replacing Oster 6329 Bread Lift Shelf, Outer Shell Removal: 手順 1、 2の画像 2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Replacing Oster 6329 Bread Lift Shelf: 手順 2、 1の画像 1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Replacing Oster 6329 Bread Lift Shelf: 手順 3、 1の画像 1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Replacing Oster 6329 Bread Lift Shelf: 手順 4、 2の画像 1 Replacing Oster 6329 Bread Lift Shelf: 手順 4、 2の画像 2
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Replacing Oster 6329 Bread Lift Shelf: 手順 5、 2の画像 1 Replacing Oster 6329 Bread Lift Shelf: 手順 5、 2の画像 2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Replacing Oster 6329 Bread Lift Shelf, Bread Lift Shelf: 手順 6、 1の画像 1
    • Use a flat-head screwdriver to separate the metal flap from the metal plate.
  7. Replacing Oster 6329 Bread Lift Shelf: 手順 7、 2の画像 1 Replacing Oster 6329 Bread Lift Shelf: 手順 7、 2の画像 2
    • Grasp the metal flap with the large needle nose pliers.
    • Unbend metal flap until at a 90 degree angle from the metal plate.
    • Repeat these steps for the second metal flap.
  8. Replacing Oster 6329 Bread Lift Shelf: 手順 8、 1の画像 1
    • Use the large need nose pliers to grab the metal panel.
    • Pull the metal panel away from the body of the toaster to dislodge the flaps.
  9. Replacing Oster 6329 Bread Lift Shelf: 手順 9、 2の画像 1 Replacing Oster 6329 Bread Lift Shelf: 手順 9、 2の画像 2
    • Push the metal flaps towards the body of the toaster to access the bread lift shelf.
  10. Replacing Oster 6329 Bread Lift Shelf: 手順 10、 1の画像 1
    • Push down on the opposite side of the bread lift shelf to expose the metal flaps.
  11. Replacing Oster 6329 Bread Lift Shelf: 手順 11、 1の画像 1
    • Pull up on the bread lift shelf to remove from the toaster.
終わりに
作成者
6人の作成者と共同で作成されました。
Jason Yoon
メンバー登録日: 01/31/14
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014人のメンバー
CPSU-REGAN-W14S13G15
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 610
