メインコンテンツにスキップ
Replacing Creative Zen X-Fi Motherboard
必要な工具と部品
  1. Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 手順 1、 3の画像 1 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 手順 1、 3の画像 2 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: 手順 1、 3の画像 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Motherboard, Rubber Button Cover: 手順 2、 1の画像 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Motherboard, Button Input Chip Part 1: 手順 3、 1の画像 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Motherboard, Button Input Chip: 手順 4、 1の画像 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Motherboard, Access Midsection Plate: 手順 5、 1の画像 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Motherboard, Unscrew below Button Chip: 手順 6、 1の画像 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Motherboard, Unscrew below LCD Screen: 手順 7、 1の画像 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: 手順 8、 2の画像 1 Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: 手順 8、 2の画像 2
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Westley Courchene
メンバー登録日: 01/13/15
3,410 ポイント
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 717
