メインコンテンツにスキップ
Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
必要な工具と部品
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: 手順 1、 1の画像 1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 2、 3の画像 1 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 2、 3の画像 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 2、 3の画像 3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 3、 2の画像 1 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 3、 2の画像 2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 4、 2の画像 1 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 4、 2の画像 2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 5、 2の画像 1 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 5、 2の画像 2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 6、 2の画像 1 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: 手順 6、 2の画像 2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Michael Loboda
メンバー登録日: 10/07/19
157 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team S2-G8, Munoz Fall 2019 Eastern Washington University, Team S2-G8, Munoz Fall 2019人のメンバー
EWU-MUNOZ-F19S2G8
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 70
今までの合計 4,046
