メインコンテンツにスキップ
Replacing Citroen C1 Spark Plugs
必要な工具と部品
  1. Replacing Citroen C1 Spark Plugs, Introduction: 手順 1、 2の画像 1 Replacing Citroen C1 Spark Plugs, Introduction: 手順 1、 2の画像 2
    • Open the engine hood of your C1, pulling the controller located below and to the left of the steering wheel.
    • Disconnect the battery.
  2. Replacing Citroen C1 Spark Plugs, Remove the air filter box 1: 手順 2、 2の画像 1 Replacing Citroen C1 Spark Plugs, Remove the air filter box 1: 手順 2、 2の画像 2
    • Identify the air filter box.
    • Pull back the hooks to detach the air filter box.
  3. Replacing Citroen C1 Spark Plugs, Remove the air filter box 2: 手順 3、 2の画像 1 Replacing Citroen C1 Spark Plugs, Remove the air filter box 2: 手順 3、 2の画像 2
    • Loosen the clamp and move it up to free the sleeve.
    • Loosen the air intake pipe clamp.
  4. Replacing Citroen C1 Spark Plugs, Remove the air filter box 3: 手順 4、 3の画像 1 Replacing Citroen C1 Spark Plugs, Remove the air filter box 3: 手順 4、 3の画像 2 Replacing Citroen C1 Spark Plugs, Remove the air filter box 3: 手順 4、 3の画像 3
    • You can now remove the air filter box.
  5. Replacing Citroen C1 Spark Plugs, Remove the ignition coils: 手順 5、 3の画像 1 Replacing Citroen C1 Spark Plugs, Remove the ignition coils: 手順 5、 3の画像 2 Replacing Citroen C1 Spark Plugs, Remove the ignition coils: 手順 5、 3の画像 3
    • Unscrew the three bolts of the ignition coils with the help of a 10mm 6-point socket.
    • Remove the three ignition coils by pulling them upwards.
  6. Replacing Citroen C1 Spark Plugs: 手順 6、 1の画像 1
    • You can choose to unplug each ignition coil connector and place them on a workbench (taking care to identify each coil), or leave the coils plugged in and stored to the left and above the engine.
  7. Replacing Citroen C1 Spark Plugs, Remove the spark plugs: 手順 7、 3の画像 1 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: 手順 7、 3の画像 2 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: 手順 7、 3の画像 3
    • Grab a spark plug wrench (size 16mm)
    • Insert the wrench into the first spark plug chamber, until you reach the bolt.
    • Certain spark plug wrench are equipped with a rubber joint to help with extracting the spark plug. It is therefore necessary to apply light pressure to correctly reach the spark plug's bolt.
    • Unscrew the first spark plug, then remove it from its chamber.
  8. Replacing Citroen C1 Spark Plugs, Remove the spark plugs: 手順 8、 3の画像 1 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: 手順 8、 3の画像 2 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: 手順 8、 3の画像 3
    • Continue in the same manner for second and third spark plugs.
  9. Replacing Citroen C1 Spark Plugs, Clean and replace the spark plugs: 手順 9、 1の画像 1
    • You can now proceed to clean or replace the spark plugs.
    • The cleaning of a spark plug can be done with contact cleaner and a brass brush.
    • To reinstall the spark plugs, repeat this procedure in reverse.
    • When reinstalling, be sure to rest the spark plug as straight as possible, to align the thread axes of each spark plug. The recommended tightening torque is 29Nm (21.4 lbft)
終わりに
To reassemble your vehicle, follow the instructions in reverse order.
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
Annieさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Subject42
メンバー登録日: 08/28/14
2,675 ポイント
4のガイドは作成済み
3 件のコメント
Tuto carré net précis ?
Bruno Bossuet - 返信
Really helpful. Many thanks.
Simon Davies - 返信
Can you pls advice the correct gap for the sparkplug.
Kind regards.
roedoe - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 32
過去 30 日: 164
今までの合計 7,801
