メインコンテンツにスキップ
Replacing Atari Lynx Buttons and D-Pad
必要な工具と部品
  1. Replacing Atari Lynx Buttons and D-Pad, Atari Lynx: 手順 1、 1の画像 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Buttons and D-Pad: 手順 2、 1の画像 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Buttons and D-Pad: 手順 3、 1の画像 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Buttons and D-Pad: 手順 4、 1の画像 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Buttons and D-Pad, Buttons and D-Pad: 手順 5、 1の画像 1
    • If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from the front panel of Atari.
  6. Replacing Atari Lynx Buttons and D-Pad: 手順 6、 2の画像 1 Replacing Atari Lynx Buttons and D-Pad: 手順 6、 2の画像 2
    • To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad.
    • The buttons should fall out once the screws have been removed.
終わりに
作成者
4人の作成者と共同で作成されました。
Tyler Williams
メンバー登録日: 01/26/14
333 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G42
5 メンバー
16のガイドは作成済み
コメント 1 件
Thanks for the guide. The title photo shows a Lynx II, however, while all the detailed instructions are for the original Lynx (I) which is built differently.
It would be great to have a Lynx II disassembly and MOSFET Q12 replacement guide.
Siegfried Lenz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 2,188
