メインコンテンツにスキップ
Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690
必要な工具と部品
  1. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690, Graphics processing unit in a HP Pavilion 690.: 手順 1、 1の画像 1
    • Power off the desktop and unplug the power cable.
    • Hold power button for 5 seconds to discharge the capacitors.
    • Remove the side panel from the computer.
  2. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 2、 1の画像 1
    • Remove screws and place screws in bowl for safe storage.
    • Place the screws in a small bowl or on a magnetic mat so they don't get lost.
  3. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 3、 2の画像 1 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 3、 2の画像 2
    • Disconnect CD-ROM drive from the computer.
    • Caution: Ensure that you are properly grounded before touching any electrical components. Computer equipment is highly susceptible to damage through electric shock.
  4. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 4、 1の画像 1
    • Press in the small black lever on the back of the CD-ROM drive.
  5. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 5、 1の画像 1
    • Remove the CD-ROM drive from the computer.
  6. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 6、 2の画像 1 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 6、 2の画像 2
    • Disconnect the wires connecting the storage housing to the motherboard.
  7. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 7、 1の画像 1
    • Remove the storage housing from the computer.
  8. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 8、 2の画像 1 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 8、 2の画像 2
    • Unscrew the screws on the latch on the back of the computer.
  9. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 9、 2の画像 1 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 9、 2の画像 2
    • Flip the open the latch on the back of the computer.
  10. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 10、 1の画像 1
    • Disconnect the power cable from the GPU.
  11. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 11、 1の画像 1
    • Press down on the small lever at the base of the GPU to release the component.
    • Caution: When reassembling do not press this lever. It can lead to an improperly seated GPU and may damage the slot or the GPU.
  12. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 12、 2の画像 1 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 12、 2の画像 2
    • Pull the GPU gently out of the computer.
  13. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 13、 2の画像 1 Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 13、 2の画像 2
    • Slide the replacement GPU into the slot.
  14. Replacement of Graphics Processing Unit (GPU) in a HP Pavilion 690: 手順 14、 1の画像 1
    • Plug the power cable into the replacement GPU.
終わりに
作成者
2人の作成者と共同で作成されました。
Yousif Al hamadani
メンバー登録日: 10/06/22
229 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 2-2, Raign Fall 2022 University of North Texas, Team 2-2, Raign Fall 2022人のメンバー
UNT-RAIGN-F22S2G2
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 445
