メインコンテンツにスキップ
Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop
必要な工具と部品
  1. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop, CMOS Battery: 手順 1、 1の画像 1
    • Make sure the laptop is off and has been unplugged from any power source.
    • Flip the laptop over to gain access to ten M2.5 x 6mm flat head screws.
  2. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 2、 3の画像 1 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 2、 3の画像 2 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 2、 3の画像 3
    • Use a Phillips #0 screwdriver to unscrew all the screws.
    • If you have another screwdriver that fits you can use that as well.
  3. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 3、 2の画像 1 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 3、 2の画像 2
    • Gently pry open the bottom cover of the laptop.
    • If this is the first time you are opening the laptop it might be harder to separate.
    • If it seems to be stuck at any point DO NOT pull harder you may have forgotten one screw.
  4. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 4、 3の画像 1 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 4、 3の画像 2 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 4、 3の画像 3
    • You need to unplug the battery to make sure that you don't get any potential static shock when you unplug any other component.
    • Lightly shake the connector to disconnect.
  5. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 5、 2の画像 1 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 5、 2の画像 2
    • Use a spudger or plastic opening tool to pry under the battery, and push forward to pop it free.
    • Be gentle when pushing to avoid potential damage to the battery holder, as your tool may slip.
  6. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 6、 2の画像 1 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 6、 2の画像 2
    • Place the new battery in by placing it over the holder and lightly pressing down.
  7. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 7、 2の画像 1 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 7、 2の画像 2
    • Reconnect the battery connector by gently pushing it in until you barely see the white.
  8. Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 8、 3の画像 1 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 8、 3の画像 2 Replacement of CMOS Battery in a Dell G3 15-3579 Gaming Laptop: 手順 8、 3の画像 3
    • Re-screw back on the cover.
    • The cover will snap back on as you screw on more screws.
終わりに
When you turn back on the laptop you will have to redo your BIOS settings.
作成者
1人の作成者と共同作成されました。
Brayden Keltz
メンバー登録日: 09/04/23
157 ポイント
1ガイドが承認済み
チーム
York University, Team 2-11, O'Regan Fall 2023 York University, Team 2-11, O'Regan Fall 2023人のメンバー
YORK-O'REGAN-F23S2G11
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 26
今までの合計 166
