メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください
Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.
    1. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances., Compilation of thermal fuse values for water heaters, used in household appliances. THERMAL FUSE or THERMO FUSE.: 手順 1、 2の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances., Compilation of thermal fuse values for water heaters, used in household appliances. THERMAL FUSE or THERMO FUSE.: 手順 1、 2の画像 2
      • This document is a summary of other documents I have already published regarding thermal fuse values for coffee machines. It is a work in progress, so as I gather more values, I will add them. Anyone who wishes can contribute values based on their knowledge or research. Together, we can create a useful database.
      • When replacing a thermal fuse, we must consider both the temperature it can withstand and the current it can handle.
      • NEVER INSTALL A THERMAL FUSE THAT WITHSTANDS LESS TEMPERATURE; always use one with the same or slightly higher rating.
      • NEVER INSTALL A THERMAL FUSE THAT WITHSTANDS LESS CURRENT, as it will overheat easily. Always use one with the same rating; if this parameter is higher, it's even better. The key factor of a thermal fuse is ITS MAXIMUM OPERATING TEMPERATURE.
      • For more information, search on Google: Thermal fuse.
      FixBotに聞いてみる
      コメントを追加
    2. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 2、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 2、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 2、 3の画像 3
      • The Nescafé Dolce Gusto Krups KP1600 coffee machine has 3 thermal fuses, 2 in the boiler and 1 in the water pump.
      • Two thermal fuses located on the boiler, secured by a metal plate and screw, both have blown.
      • 133º - 10A
      • RELATED DOCUMENT, MORE EXTENSIVE: https://es.ifixit.com/Gu%C3%ADa/CAFETERA...
      FixBotに聞いてみる
      コメントを追加
    3. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 3、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 3、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 3、 3の画像 3
      • Nescafé Dolce Gusto Krups KP1600 coffee machine water pump fuse.
      • Located in the body of the water pump, inserted, easy to extract. When the pump is installed, it is barely visible.
      • 113º - 10A
      • As an observation: This fuse rarely blows; the water pump winding is usually damaged first.
      FixBotに聞いてみる
      コメントを追加
    4. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 4、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 4、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 4、 3の画像 3
      • Nespresso coffee machines, Delonghi, and many similar models.
      • 2 thermal fuses on the boiler, one on each side, secured by a metal plate and screw.
      • 167º - 5 A
      FixBotに聞いてみる
      コメントを追加
    5. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 5、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 5、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 5、 3の画像 3
      • Saeco Via Veneto coffee machine: 1 thermal fuse located on the boiler at the top of the machine.
      • 186º - 5A. In the market, we can find a compatible one rated for 192º.
      • It is a common fault for this model: the machine is dead due to a blown thermal fuse. There are some videos on YouTube about it.
      FixBotに聞いてみる
      コメントを追加
    6. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 6、 1の画像 1
      • NOTE: The replacement of thermal fuses is done with electrician-type terminal blocks, isolating the entire body (NOTE: in the photo, it is still pending isolation). The fuses are crimped at their connection to the wire. If they need to be soldered, there is a technique to prevent damage, by holding them with a wet cloth or an ice cube.
      FixBotに聞いてみる
      コメントを追加
    7. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 7、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 7、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 7、 3の画像 3
      • Princess Hot Air Fryer: Thermal Fuse Value AUPO BF172 172º / 10 A / 250V - G1 is located on the metal plate of the heating element, requiring almost complete disassembly. It has 2 fuses enclosed in textile tubes, and usually, one of them blows. This causes the fryer to stop heating and the fan to stop rotating, although the display still turns on.
      • Repair guide: New contribution made 09/07/2023.
      FixBotに聞いてみる
      コメントを追加
    8. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 8、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 8、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 8、 3の画像 3
      • Equation DL06 Stand Air Convector, dead, does not turn on.
      • Thermal fuse fault at 157º, replaced with one rated for 192º, slightly moving it away from the support using electrician terminal blocks.
      • Related repair guide
      FixBotに聞いてみる
      コメントを追加
    9. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 9、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    10. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 10、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 10、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 10、 3の画像 3
      FixBotに聞いてみる
      コメントを追加
    11. Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 11、 3の画像 1 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 11、 3の画像 2 Replacement for Compilation of thermal fuse values ​​for boilers, used in household appliances.: 手順 11、 3の画像 3
      • RIVER PA-4628-A griddle does not heat up or light the thermostat pilot light. 117ºC 16A THERMAL FUSE.
      • TO BE CONTINUED... WHEN I GATHER MORE DATA ON DEVICES WITH THERMAL FUSES, you can contribute to this document by sharing what you have been able to find out about other coffee makers and equipment.
      FixBotに聞いてみる
      コメントを追加
終わりに
Informative guide under construction
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
es en
88%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Carlos López (España - Spain)
メンバー登録日: 07/01/15
101,769 ポイント
368のガイドは作成済み
7件のガイドコメント
Hola!
No me parece adecuado sustituir los fusibles quemados por otros de más temperatura. El fabricante estableció una temperatura maxima de seguridad que no permita que se dañen otros componentes, si sustituimos por uno de mayor capacidad, permitirá que el dispositivo se caliente másy se puedan ocasionar daños irreversibles en otras piezas mas costosas o insustituibles. Por otra parte, cambiarlos por otros de menor temperatura de corte, hará que salten en regimen de uso normal.
Arduinoxino - 返信 共有
Hola, Respeto tu opinion, pero por experiencia en numerosas reparaciones, el fusible termico se puede colocar de un valor ligeramente mayor ya que realmente sigue cumpliendo su función, en los aparatos que lo cambiar si tienen sobretemperatura se funde igualmente.
Carlos López (España - Spain) - 返信 共有
¿Puedo cambiar un fusible 172 por uno 192 en una free air?
Fernando Bravo - 返信 共有
Si, realmente son 20 º de diferencia a esa temperatura elevada la proteccion seguira siendo la misma
Please tell me how to dissasemble the same model Nespresso/Delonghi coffee maker as you show in your pictures. Or maybe you have a PDSF of the repair manual you could post here. I can not find any instructions or videos showing the removal of the outside panels for that model. It has rivets not screws on the bottom and elsewhere. I need to know if the side panels have plastic clips holding them or those rivets. Also, can you verify this model has a thermal fuse for the pump? Mine starts and lights up correctly when you push the power button, it gets hot but then the pump doesn't start when you push the coffee button. I believe I know how I accidentally overheated it yesterday causing the pump thermalfuse to blow..
Michele Duval - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 51
過去 30 日: 234
今までの合計 10,089
