メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
    • Insérer un commentaire.
ゴール
21 の人々がこのガイドを完成させました。
ian mdx
メンバー登録日: 2016年06月30日
7,831 ポイント
17のガイドは作成済み
8 件のコメント
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - 返信
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - 返信
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - 返信
Will the phone remain waterproof after this repair?
cj-dm - 返信
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 88
今までの合計 22,116
