必要な工具と部品
Open the latch on the right side that secures the battery in place.
Open the latch on the left side that secures the battery in place.
Now remove the battery.
Using a Philips-head screwdriver remove highlighted screws.
Look at the marking to see how to remove the access cover.
Remove the access cover as shown by the marker.
Here is the default installed memory module.
Locate and squeeze the tension springs that secure the memory module apart.
Pull the memory module (RAM) out of its plug.
To assemble the device again, proceed in reverse order.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
irlandaさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
