メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Replace defective capacitor in a power supply
必要な工具と部品
    • ATTENTION: 230V are processed in the monitor. So take the necessary care. And a little experience with electronics and soldering should be available.
  1. Replace defective capacitor in a power supply: 手順 2、 1の画像 1
    • The main focus here is on troubleshooting. First disconnect all plugs and then loosen the housing screws.
    • Now check whether an electrolytic capacitor has "blown up". Most electrolytic capacitors have a notched cross at the top and are flat there. If this surface is curved upwards, the electrolytic capacitor is defective.
    • When this top has burst open or liquid has leaked out of the electrolytic capacitor at the bottom, it is defective.
    • The liquid can also cause damage to the circuit board. In this case, the circuit board should be cleaned with isopropanol and any damaged lines must be repaired before installing a new electrolytic capacitor.
    • Now remove the circuit board. To do this, loosen all connections and remove the corresponding screws.
    • Next, the defective electrolytic capacitor must be desoldered (desoldering pump or desoldering wire help).
    • Now replace the defective electrolytic capacitor. The new electrolytic capacitor must have the same capacitance and voltage. The connection wires and height should also be the same.
    • Now reinsert the circuit board and make all connections again.
    • Then screw the cover back on.
終わりに
Work through the steps in reverse order to reassemble your device.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
oldturkey03さんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
3人の作成者と共同で作成されました。
HRi
メンバー登録日: 01/24/22
133 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 62
過去 30 日: 249
今までの合計 4,139
