メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Replace BlackBerry 7130e Speaker
必要な工具と部品
  1. Replace BlackBerry 7130e Speaker, battery: 手順 1、 1の画像 1
    • Turn the phone over so that the screen is facing the work surface
  2. Replace BlackBerry 7130e Speaker: 手順 2、 1の画像 1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. Replace BlackBerry 7130e Speaker: 手順 3、 1の画像 1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
  4. Replace BlackBerry 7130e Speaker, BlackBerry 7130e Disassembly: 手順 4、 1の画像 1
    • Using the T6 Torx screwdriver, remove the bottom two screws on the back of the phone.
  5. Replace BlackBerry 7130e Speaker: 手順 5、 1の画像 1
    • Remove speaker phone cover by unsecuring the two latches on the edge close to top of the phone with the plastic opening tool.
  6. Replace BlackBerry 7130e Speaker: 手順 6、 1の画像 1
    • Detach the speaker phone cover by pulling up on the bottom of the speaker phone cover.
    • As you detach the speaker phone cover you will notice a sticky glue sealing the rubber gasket from the cover to the speaker mesh. This is normal and will correctly reset the first few times the pieces are separated.
  7. Replace BlackBerry 7130e Speaker: 手順 7、 1の画像 1
    • Remove top two screws with T6 Torx screw driver, from the back of phone.
  8. Replace BlackBerry 7130e Speaker: 手順 8、 1の画像 1
    • Turn the phone sideways and unlatch the hinge on one side of the phone by pushing inwards and twisting to the side with the plastic opening tool.
  9. Replace BlackBerry 7130e Speaker: 手順 9、 2の画像 1 Replace BlackBerry 7130e Speaker: 手順 9、 2の画像 2
    • You should now be able to easily separate the phone into two pieces.
    • The battery prong may fall out when the separation occurs, just don't loose it!
  10. Replace BlackBerry 7130e Speaker, speaker: 手順 10、 1の画像 1
    • Set aside the bottom part of the phone.
    • Drop out the rubber keypad from the top, so that it does not get in the way.
  11. Replace BlackBerry 7130e Speaker: 手順 11、 1の画像 1
    • Use the plastic separator tool to apply significant pressure in a downward motion on the top of the white speaker unit.
  12. Replace BlackBerry 7130e Speaker: 手順 12、 1の画像 1
    • The speaker unit should become loose.
    • You can now push the separating tool beneath the speaker and pop it out.
    • Once the defective unit is removed, pop your new speaker unit back into place.
終わりに
作成者
4人の作成者と共同で作成されました。
Sean Tiernan
メンバー登録日: 01/20/10
5 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-16, Maness Winter 2010 Cal Poly, Team 3-16, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S3G16
4 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 19
過去 30 日: 64
今までの合計 1,436
