メインコンテンツにスキップ
How to remove scratches from an Airpods Case
必要な工具と部品
  1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: 手順 1、 2の画像 1 How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: 手順 1、 2の画像 2
    • The front and back are already scarred.
  2. How to remove scratches from an Airpods Case: 手順 2、 1の画像 1
    • Use 2000 grit and above fine-grained sandpaper.
    • For this tutorial, I used 2500 grit directly and then 3000 grit for a finer finish.
    • Careful when choosing a grit, a too coarse sandpaper grit will damage the airpods case
  3. How to remove scratches from an Airpods Case: 手順 3、 1の画像 1
    • Cotton wool and medical alcohol are used to clean the surface of the charging case.
  4. How to remove scratches from an Airpods Case: 手順 4、 2の画像 1 How to remove scratches from an Airpods Case: 手順 4、 2の画像 2
    • Clean the surface of the charging case with absorbent cotton dipped in alcohol.
    • Clean up the inside too!
  5. How to remove scratches from an Airpods Case: 手順 5、 1の画像 1
    • Wet the surface with absorbent cotton or a little water, and then lightly sand it with 2500-grit fine sandpaper.
    • It can be seen that the more serious scratches have been smoothed out, the polished areas have turned white, and the smooth surface has become matte.
    • This step can be performed as many times as necessary.
  6. How to remove scratches from an Airpods Case: 手順 6、 1の画像 1
    • It has now returned to white, but the surface is still matte.
    • If you like this matte style, you can stop
    • To restore a smooth surface, continue sanding with 3000 grit sandpaper in the same way as in the previous step.
    • The finer the sandpaper, the smoother it will be.
  7. How to remove scratches from an Airpods Case: 手順 7、 1の画像 1
    • Refreshed now!
終わりに
This will give the charging case a refreshed look instead of a dirty, scratched surface.
27 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
zh en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Z.Heng
メンバー登録日: 04/08/17
3,610 ポイント
3のガイドは作成済み
8 件のコメント
Extremely convincing, especially the last picture.
Ludger - 返信
感谢作者!我的AirPods也布满了划痕!
Zhang Boyang - 返信
Kann man auch Polierpaste nutzen wie sie für Kunststoffdisplays benutzt wird?
neo1983-jahn - 返信
How big can the scratches be ?
Albert zweisteim - 返信
How do you get it shiny again?
lucas cheraki - 返信
コメントを追加
統計データ:
過去 24時間: 37
過去 7 日: 236
過去 30 日: 1,071
今までの合計 75,964
