はじめに
This guide will show you how to get to the LEDs and how to inspect the circuit board. If there is a faulty connection or a loose wire, this guide shows displays a quick solution.
ツール
パーツ
パーツは指定されていません。
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
ある他の人がこのガイドを完成しました。
2 件のコメント
Good stuff except for the fact that the most common problem(fan not working) that is for me, the first and simplest repair listed is referred to a dead end in led repair section. I could be wrong, but still, where is the fuse and how does the ohm meter work for a fuse test again? Hey, your fixer guide is the one that brought it up in the first place. Just saying.....
