この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help you repair the buttons on the Seville Classics MSC10166 Tower Fan.
必要な工具と部品
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
2 の人々がこのガイドを完成させました。
2 件のコメント
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
