メインコンテンツにスキップ
Repairing Paint Brush Bristles
必要な工具と部品
  1. Repairing Paint Brush Bristles, Repairing Paint Brush Bristles: 手順 1、 2の画像 1 Repairing Paint Brush Bristles, Repairing Paint Brush Bristles: 手順 1、 2の画像 2
    • Identify the brush type and the level of damage:
    • If the brush hairs are inflexible due to hardened paint coats, proceed to Step 2.
    • If the brush hairs are synthetic (fraying bristles), proceed to Step 5.
  2. Repairing Paint Brush Bristles: 手順 2、 2の画像 1 Repairing Paint Brush Bristles: 手順 2、 2の画像 2
    • Fill a small cup half way with turpentine.
    • Soak the brush in the turpentine for 2 days.
    • CAUTION: Do this in a well-ventilated area. The fumes from turpentine are toxic.
  3. Repairing Paint Brush Bristles: 手順 3、 1の画像 1
    • Remove any amount of paint that may remain on the brush by moving the brush in a circular motion.
  4. Repairing Paint Brush Bristles: 手順 4、 2の画像 1 Repairing Paint Brush Bristles: 手順 4、 2の画像 2
    • To remove remnants of turpentine on the bristles, wash the brush thoroughly in water.
    • After the turpentine has been completely removed, proceed to Step 7.
  5. Repairing Paint Brush Bristles: 手順 5、 1の画像 1
    • For synthetic brushes, boil a pot of water.
    • CAUTION: Avoid any contact with hot objects.
  6. Repairing Paint Brush Bristles: 手順 6、 2の画像 1 Repairing Paint Brush Bristles: 手順 6、 2の画像 2
    • Place the brush in the boiling water.
    • Rotate the brush in the water for approximately 5 minutes.
    • You should begin to notice that the bristles will start to come back together from the heat and water.
  7. Repairing Paint Brush Bristles: 手順 7、 2の画像 1 Repairing Paint Brush Bristles: 手順 7、 2の画像 2
    • Gently dry off the brushes using a soft towel.
    • Stroke the brush in an upward motion and be careful not to dig the towel through the bristles.
  8. Repairing Paint Brush Bristles: 手順 8、 3の画像 1 Repairing Paint Brush Bristles: 手順 8、 3の画像 2 Repairing Paint Brush Bristles: 手順 8、 3の画像 3
    • In order to retain the brush shape, use a brush tube or wrap the bristles in aluminum foil.
    • Within approximately three hours, the brush bristles will be back to normal.
  9. Repairing Paint Brush Bristles: 手順 9、 2の画像 1 Repairing Paint Brush Bristles: 手順 9、 2の画像 2
    • Cut off excess frayed bristles (optional).
    • There may be a few fraying bristles left. These are harmless and will cling to the brush shape when dipped in paint.
    • If preferred, you may use a nail clipper to cut these hairs off.
終わりに
Your brushes should now be usable again. Unfortunately this cannot be done too many times because the turpentine will start to damage the bristles, so make sure to regularly wash your brushes.
23 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Ankita Bhowmik
メンバー登録日: 09/29/15
659 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-7, Green Fall 2015 Cal Poly, Team 15-7, Green Fall 2015人のメンバー
CPSU-GREEN-F15S15G7
3 メンバー
7のガイドは作成済み
6 件のコメント
Is this only for synthetic brushes? What about natural hair brushes which are frayed?
radhikacr999 - 返信
Hey! Can you tell me what is the use of wrapping the bristles in aluminium foil?
Santwana Verma - 返信
The article literally says “to retain the brush shape”
Paul Peddie -
I’ve seen other tutorials say to mix vinegar with the boiled water, would you recommend it?
John Ippoliti - 返信
Awesome guide, By the way, this guide "Can You Spray Stain With An Airless Sprayer" also contain useful information.
Muhammad Usman Bhatti - 返信
コメントを追加
統計データ:
過去 24時間: 25
過去 7 日: 151
過去 30 日: 723
今までの合計 139,043
