メインコンテンツにスキップ
Repairing and Reinforcing a Closet Rack
必要な工具と部品
  1. Repairing and Reinforcing a Closet Rack, Brackets Braces C-Clamps: 手順 1、 1の画像 1
    • Use the putty knife and spread the dry wall compound filling any holes and damage made to the wall.
  2. Repairing and Reinforcing a Closet Rack: 手順 2、 1の画像 1
    • Allow the compound to dry off so as to reach maximum hardness.
  3. Repairing and Reinforcing a Closet Rack: 手順 3、 1の画像 1
    • Use the 100 grit sandpaper and gently sand down the areas that were puttied, thus making them flush with the wall.
    • Use safety glasses and a dust mask protecting both your lungs and eyes from any particles coming off the wall.
  4. Repairing and Reinforcing a Closet Rack: 手順 4、 1の画像 1
    • Measure and mark where the new holes will go for the brackets, c-clamps, and braces.
    • Allow 11"-12" of space between the side wall and the first bracket and each subsequent bracket.
    • Mark holes for the c-clamps half the distance between the brackets.
    • Use a level to guarantee the rack will be straight.
  5. Repairing and Reinforcing a Closet Rack: 手順 5、 1の画像 1
    • Use a drill with a 1/4" drill bit and make holes at each mark.
    • Use safety glasses when operating the drill, and be cautious and careful when handling the drill. Careless handling of the drill can lead to injury. For more information on how to properly handle a drill refer to this guide's introduction.
  6. Repairing and Reinforcing a Closet Rack: 手順 6、 1の画像 1
    • Use a hammer and knock the plastic anchors into the wall where the holes were drilled.
    • Use #8 plastic anchors for best results.
  7. Repairing and Reinforcing a Closet Rack: 手順 7、 1の画像 1
    • Use a brush and matching wall paint to coat the areas that were puttied and allow it to dry.
  8. Repairing and Reinforcing a Closet Rack: 手順 8、 1の画像 1
    • Use a flathead screwdriver and screw the brackets into the plastic anchors.
    • Use 1-1/4" flathead screws for best results.
  9. Repairing and Reinforcing a Closet Rack: 手順 9、 1の画像 1
    • Take the closet rack and place it onto the brackets.
  10. Repairing and Reinforcing a Closet Rack: 手順 10、 1の画像 1
    • Use a Phillips screw driver to screw the c-clamps into the plastic anchors and reinforce the rack.
    • Use Phillips #8 1-1/4" screws for best results.
  11. Repairing and Reinforcing a Closet Rack: 手順 11、 1の画像 1
    • Place the support braces on the rack.
    • Use a Phillips screw driver to screw them into the plastic anchors.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Bojan Krtinic
メンバー登録日: 05/12/20
220 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G16, O'Regan Summer 2020 York University, Team S1-G16, O'Regan Summer 2020人のメンバー
YORK-O'REGAN-SU20S1G16
1 メンバー
2のガイドは作成済み
コメント 1 件
Just a question what if you wanted to install a heavier more solid longer rod?
Chris M - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 63
過去 30 日: 268
今までの合計 5,861
