はじめに
This guide is to instruct you on how to fix a wobbly piano bench seat. Fixing this problem would result in a firm and balanced piano bench seat. While, eliminating possible noise coming from the bench as you are seated on it, and give you confidence in the structure of the piano bench seat, to allow you to be focused while playing your piano. There are no specialty skills or tools that are necessary, other than the knowledge of how to use a smart wrench. Following the guide properly, and in the step's order as instructed, should allow for you to repair your wobbly piano bench seat with ease.
必要な工具と部品
You can redo this process every 6 months to make sure your bench is always stable.
ある他の人がこのガイドを完成しました。
