メインコンテンツにスキップ
Repairing a Tear in a Tent
必要な工具と部品
  1. Repairing a Tear in a Tent, Sew a Ladder Stitch: 手順 1、 3の画像 1 Repairing a Tear in a Tent, Sew a Ladder Stitch: 手順 1、 3の画像 2 Repairing a Tear in a Tent, Sew a Ladder Stitch: 手順 1、 3の画像 3
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Repairing a Tear in a Tent: 手順 2、 2の画像 1 Repairing a Tear in a Tent: 手順 2、 2の画像 2
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Repairing a Tear in a Tent: 手順 3、 2の画像 1 Repairing a Tear in a Tent: 手順 3、 2の画像 2
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Repairing a Tear in a Tent: 手順 4、 2の画像 1 Repairing a Tear in a Tent: 手順 4、 2の画像 2
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Repairing a Tear in a Tent: 手順 5、 3の画像 1 Repairing a Tear in a Tent: 手順 5、 3の画像 2 Repairing a Tear in a Tent: 手順 5、 3の画像 3
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
ゴール
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,012 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,767のガイドは作成済み
コメント 1 件
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
https://www.amazon.com/Fixmytear-Magic-R...
https://www.amazon.com/fixmytear-Magic-R...
bobhunter50023 - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 70
過去 30 日: 281
今までの合計 7,675
