はじめに
Is your Zippo lighter not working because the flint wheel is stuck? Don't want to invest money in a brand new lighter? Your flint wheel is stuck because the steel rod it strikes is stuck at an awkward position against the wheel causing the wheel to be immobile. Find out how to loosen the steel rod and fix your Zippo!
ツール
パーツ
パーツは指定されていません。
Open your Zippo lighter and take the inside component out of the shell simply by pulling it out.
You have now fixed your flint wheel! Enjoy your Zippo Lighter!
24 の人々がこのガイドを完成させました。
22 件のコメント
This made the problem even worse. The flint wheel is now unstuck but it can't make any sparks whatsoever.
me too it will not work i did the same and now it wont make sparks
cool kid -
Did you change the flint aswell? Change the flint and put it back together, if it won’t turn after changing the flint then loosen the spring again.
You need to replace the flint itself in that case.
Wonderful instructions! AND IT WORKED! Thank you.
John Heard - 返信
