メインコンテンツにスキップ
Repairing a Broken Coffee Mug Handle
必要な工具と部品
  1. Repairing a Broken Coffee Mug Handle, Repairing a Broken Coffee Mug Handle: 手順 1、 1の画像 1
    • Wash your mug clean and rinse the broken edges. Handle carefully to prevent further damage.
    • Make sure you don't cut yourself on any sharp edges.
  2. Repairing a Broken Coffee Mug Handle: 手順 2、 3の画像 1 Repairing a Broken Coffee Mug Handle: 手順 2、 3の画像 2 Repairing a Broken Coffee Mug Handle: 手順 2、 3の画像 3
    • Collect the pieces of the handle and place them on a few paper towels.
    • Piece them back together and make sure all of the parts are there.
  3. Repairing a Broken Coffee Mug Handle: 手順 3、 2の画像 1 Repairing a Broken Coffee Mug Handle: 手順 3、 2の画像 2
    • Take two of the broken pieces that fit together and glue them.
    • Cover the piece in a thin layer of glue (about one drop) and try to avoid getting glue on your hands, keep paper towels close by incase you do.
  4. Repairing a Broken Coffee Mug Handle: 手順 4、 3の画像 1 Repairing a Broken Coffee Mug Handle: 手順 4、 3の画像 2 Repairing a Broken Coffee Mug Handle: 手順 4、 3の画像 3
    • Continue glueing other pieces of the handle in place until all pieces are together.
    • Once the handle is glued together, wait for the glue to dry before moving on. It will take about 30 minutes to dry.
    • Be very delicate with the piece while it is drying. Before the glue sets the handle will be very fragile.
  5. Repairing a Broken Coffee Mug Handle: 手順 5、 2の画像 1 Repairing a Broken Coffee Mug Handle: 手順 5、 2の画像 2
    • After the handle has dried, test that the glued pieces are sturdy.
    • Do not purposely break it apart, but make sure that the pieces are secure.
    • If the handle happens to break anywhere, repeat step 4.
  6. Repairing a Broken Coffee Mug Handle: 手順 6、 3の画像 1 Repairing a Broken Coffee Mug Handle: 手順 6、 3の画像 2 Repairing a Broken Coffee Mug Handle: 手順 6、 3の画像 3
    • Once the handle is dried and secure. Begin placing glue on the cup where the handle should attach.
    • After gluing both places, gently press handle ends into place.
    • The handle should fit in almost perfectly when alined.
  7. Repairing a Broken Coffee Mug Handle: 手順 7、 3の画像 1 Repairing a Broken Coffee Mug Handle: 手順 7、 3の画像 2 Repairing a Broken Coffee Mug Handle: 手順 7、 3の画像 3
    • Now let the glue dry, and your mug is usable again.
    • Remember it will take about 30 minutes to dry.
    • I would not advise washing this mug in the dishwasher anymore because this makes it more likely to break again.
終わりに
After completing all steps your mug will now be able to be used again. Remember that the handle is no longer dishwasher or microwave safe.
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kathryn Webb
メンバー登録日: 04/09/15
254 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 28-2, Green Spring 2015 Cal Poly, Team 28-2, Green Spring 2015人のメンバー
CPSU-GREEN-S15S28G2
4 メンバー
2のガイドは作成済み
6 件のコメント
In Step 2, we would advise against handling any of the smallest shards of the mug. For safety reasons, we would just stick to adhering the larger, less sharp pieces of the broken handle.
Do you recommend any specific type of glue? Some glues (such as Gorilla glue) need to be applied in a very small amount, due to expansion. Make sure you give instructions as to how much glue to apply (apply a pea-sized amount, apply enough so that it covers the whole piece, etc.) Does the mug need to be damp before applying glue?
Approximately how long did it take for the glue to dry? Results may vary from person to person, but it's a good idea to give an estimated time frame. "After completing all steps your mug will now be able to be used again. Remember that the handle is no longer dishwasher or microwave safe," should be placed either in the intro or as a special bullet in your guide. The audience should know this before they begin the repair.
Kathryn Webb - 返信
Be sure to have all team members proofread the text for spelling, grammar, and punctuation. We have noticed the misspelling of "break" throughout your guide.
Kathryn Webb - 返信
Thank God we always have the spelling and grammar police on the internet and I bet she is a Democrat.
Wolfman - 返信
Disappointed by the instructions… everyone can guess how to put the pieces together so the right ones are next to each other. But…
you should start with: “it is no longer dishwasher/microwave safe”.
Why? Is it a glue? or just an assumption?
What kind of glue did you use? Does it say the glue will not be safe in the dishwasher?
findbostonhome - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 113
今までの合計 37,229
