はじめに
This guide will attempt to fix a common issue with the VHT 510 model. If your volume indicator has stopped working or never worked to begin with, this guide can help troubleshoot the problem.
I completed this guide in order to educate people and provide a source of information on this widely known issue.
必要な工具と部品
Remove the speaker grille by gently prying it from either side of the bar.
Start on one end by prying the grille until it comes free.
Do the same on the other side.
Work your way towards the center by prying gentling.
A plastic credit card can help in removing the grille. Place the sound bar face down and starting at one end, insert or slide the short side of the card between the black plastic grille frame and the short side of the sound bar shell.
Pick up the sound bar and gently push downward to begin separating the grille cover and frame from the sound bar shell.
As the two begin to come apart, it's fairly easy to move the card around and use a combination of pushing, pulling and wiggling to get the grille separated.
Remember to use extreme care so as not to damage the grille frame, grille cover or the wiring attached to the grille.
The solder points are extremely close and if they are in contact the leds will stop working.
With your soldering iron, heat each leg individually and attempt to make more space between the two points.
This process can take time so don't worry if the solder points come together. Just keep heating one up at a time and try to create a gap.
Before putting your speaker back together I recommend testing it to make sure the fix worked.
Also, if you feel like the power and other indicator lights are too bright, now is a good chance to gently bend the legs of the led's upward to diffuse the light.
One final note. I did notice that disconnecting and reseating the two cables connected to the speaker grill while the speaker is powered on will sometimes get the leds to start working. I hope this helps someone.
3 の人々がこのガイドを完成させました。
6 件のコメント
Pics please, i tried to figure out the cap and resistor being talked about.
However their solder points were close but to the naked eye they didnt seem to be connected. Also however hard i tried, i could always test it postive for connectivity using a Digital MultiMeter. It seems they were designed to be on the same PCB track or connected or something..
Pics would be really helpful as this affects nearly all of the VHT 510 users... thanks
Let me know if these photos help. I'm not an electrician but this is how I fixed my sound bar.
Johnny -
