メインコンテンツにスキップ
Repairing VTech Touch and Swipe Baby Phone Screen Alignment
必要な工具と部品
  1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: 手順 1、 2の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: 手順 1、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 2、 3の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 2、 3の画像 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 2、 3の画像 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 3、 3の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 3、 3の画像 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 3、 3の画像 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 4、 2の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 4、 2の画像 2
    • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
  5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 5、 3の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 5、 3の画像 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 5、 3の画像 3
    • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
  6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 6、 2の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 6、 2の画像 2
    • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
    • Slide off the spring.
  7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 7、 3の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 7、 3の画像 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 7、 3の画像 3
    • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
    • Lift up the black plastic piece.
  8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 8、 2の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 8、 2の画像 2
    • Remove four 7.5mm screws with a Phillips #0 screwdriver.
  9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 9、 2の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 9、 2の画像 2
    • Remove the two buttons, noting how wires are placed for reassembly.
  10. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 10、 2の画像 1 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 10、 2の画像 2
    • Lift the button board up and away to clear room for lifting the motherboard.
    • Tilt the assembly up but being wary that it is still attached to the front panel.
  11. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 11、 1の画像 1
    • Slide the toothed slider towards you to remove.
  12. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: 手順 12、 1の画像 1
    • To reassemble, align the two black lines together by moving the belt back and forth.
    • Once aligned reinsert the toothed slider at the exact point shown.
    be careful at the top blue button (on/off) that might come off when you align the belt
    cipriansoleriu - 返信
終わりに
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Sean Webb
メンバー登録日: 09/04/15
384 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015人のメンバー
USFT-SULLIVAN-F15S2G4
3 メンバー
12のガイドは作成済み
コメント 1 件
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,286
