メインコンテンツにスキップ
Repairing Turtle Beach PX22 Sticky Volume Wheels
必要な工具と部品
  1. Repairing Turtle Beach PX22 Sticky Volume Wheels, Repairing Turtle Beach PX22 Sticky Volume Wheels: 手順 1、 2の画像 1 Repairing Turtle Beach PX22 Sticky Volume Wheels, Repairing Turtle Beach PX22 Sticky Volume Wheels: 手順 1、 2の画像 2
    • Remove the 4 screws from the inline amplifier using a #6 torque screwdriver head. The screws measure 1/4" long and 3/32" in diameter.
    • Open the amplifier by using the smaller plastic opening tool. Place it in the headphone jack and use leverage to pry open the plastic halves.
    • Be aware of the small plastic cylinder that braces the headphone jack.
  2. Repairing Turtle Beach PX22 Sticky Volume Wheels: 手順 2、 2の画像 1 Repairing Turtle Beach PX22 Sticky Volume Wheels: 手順 2、 2の画像 2
    • Remove the circuit board from the plastic housing and flip it so that you can see the scroll wheels.
    • Using a cloth dipped in isopropyl rubbing alcohol, clean the affected scroll wheels.
    • 90-100% isopropyl alcohol is preferred for cleaning.
  3. Repairing Turtle Beach PX22 Sticky Volume Wheels: 手順 3、 3の画像 1 Repairing Turtle Beach PX22 Sticky Volume Wheels: 手順 3、 3の画像 2 Repairing Turtle Beach PX22 Sticky Volume Wheels: 手順 3、 3の画像 3
    • When done cleaning, place the circuit board back in the plastic housing.
    • The scroll wheels should be facing the housing with the logo and labels, and should slide onto the 4 screw holes.
    • Make sure the plastic headphone jack brace is in position.
    • Position the wire in the slot on the other side of the amplifier, it should slide down onto the housing and become fixed.
    • Close the housing with the other plastic half. It will click into place.
    • Replace the 4 screws using the #6 torque screwdriver.
終わりに
作成者
4人の作成者と共同で作成されました。
James de Iturrondo
メンバー登録日: 03/18/15
709 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 3-1, Duarte Spring 2015 UMass Dartmouth, Team 3-1, Duarte Spring 2015人のメンバー
UMASSD-DUARTE-S15S3G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 1,421
