はじめに
A loose piece of velcro can leave your tent prey to the wind. Sew it back on using a whip stitch.
While you can glue a piece of velcro back into place, some adhesives may cause the tent material to become brittle and tear. Sewing is a simple alternative.
In addition to velcro, this procedure works for sewing almost any other fabric component of the tent back into place.
必要な工具と部品
Align the two pieces of material you will be stitching together.
Thread your needle and tie a knot in the end of the thread.
Drive the needle into the bottom layer of material from the back side.
Slowly start to pull the thread taut. As you pull, you will see a loop form.
Draw the needle through the loop.
Pull the thread taut, forming a knot.
Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
ある他の人がこのガイドを完成しました。
コメント 1 件
If you remembered to pack a needle, but forgot a spool of thread, and a field repair is in order: go see whether you packed any dental floss. If so, you have some hardy thread indeed, and if you bought the green minty kind, you may discover a whiff of mint now and again emanating from your repair site. I try to remember to buy the old string type of floss rather than the newer kind with flat bits, but if your needle has a big enough eye, you can thread either sort. Careful now, too thick a needle may give you threading holes larger than you want. If the repair is in a location that may leak, there are a wide variety of different things you can use to seal your sewn repair and enjoy a drier tent interior. As my preference is for canvas tents over nylon, I use beeswax, but I think a silicone spray would nicely seal a repair to nylon.
