はじめに
This comprehensive guide will walk you through disassembling your headset, locating any problems with your left speaker, and making repairs. If your device is still under warranty, please contact Tritton for a replacement before attempting these repairs and possibly voiding your warranty.
The repairs in this guide require soldering, please refer to this guide and/or this article from iFixit for additional help.
必要な工具と部品
Grab the ear cushion between your thumb and finger.
Carefully pull the ear cushion away from the speaker frame until they separate.
This is the circuit board for the USB connection to the speakers.
Inspect the five solder points for a broken wire connection. They are labeled SP-, M-, M+, R-, and R.
If any connections are broken, re-solder the wires. Use this image as a reference for correct wiring.
If your speaker is now working, skip to the conclusion.
To reassemble your device, follow steps 1 through 4 in reverse order.
ある他の人がこのガイドを完成しました。
