メインコンテンツにスキップ
Repairing Sony Cyber-shot DSC-W290 LCD
必要な工具と部品
  1. Repairing Sony Cyber-shot DSC-W290 LCD, Battery: 手順 1、 1の画像 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 2、 1の画像 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Repairing Sony Cyber-shot DSC-W290 LCD, Outer Casing: 手順 3、 2の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD, Outer Casing: 手順 3、 2の画像 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 4、 3の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 4、 3の画像 2 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 4、 3の画像 3
    この手順で使用する道具:
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 5、 3の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 5、 3の画像 2 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 5、 3の画像 3
    • Turn the camera so the right side faces you.
  6. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 6、 1の画像 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 7、 2の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 7、 2の画像 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 8、 2の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 8、 2の画像 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 9、 2の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 9、 2の画像 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 10、 2の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 10、 2の画像 2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Repairing Sony Cyber-shot DSC-W290 LCD, LCD Assembly: 手順 11、 1の画像 1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 12、 2の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 12、 2の画像 2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 13、 2の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 13、 2の画像 2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 14、 1の画像 1
    • Pull the LCD and its casing away from the rest of the camera.
  15. Repairing Sony Cyber-shot DSC-W290 LCD, LCD: 手順 15、 3の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD, LCD: 手順 15、 3の画像 2 Repairing Sony Cyber-shot DSC-W290 LCD, LCD: 手順 15、 3の画像 3
    • Rotate the LCD and its casing so that the screen is facing you.
    • Gently pull the control panel downward, freeing it from the small metal clips.
    • Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
  16. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 16、 3の画像 1 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 16、 3の画像 2 Repairing Sony Cyber-shot DSC-W290 LCD: 手順 16、 3の画像 3
    • Lift the LCD away from the metal casing on the right side.
    • Slide the LCD to the right and away from the metal casing.
    • Carefully pull the ribbon-wire out of the opening in the metal casing.
  17. Repairing Sony Cyber-shot DSC-W290 LCD: 手順 17、 1の画像 1
    • The LCD is now out of the camera.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
William Schill
メンバー登録日: 10/04/10
225 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 7-54, Amido Fall 2010 Cal Poly, Team 7-54, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S7G54
4 メンバー
16のガイドは作成済み
1件のガイドコメント
donde puedo conseguir la pantalla? porque la mia se estrello :(
miguel - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 24
今までの合計 7,076
