はじめに
This guide assumes you have a reasonable understanding of soldering and desoldering techniques. You will be able to remove the power supply board, locate and examine the likely faulty capacitors. This guide is accurate for the LA40R81BD model however there are many similar models that experience similar issues so you may find it useful in repairing other model Samsung TV's
必要な工具と部品
Using a Philips driver remove the 18 screws from the rear panel.
Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Remove the 7 connectors from the board
Remove the 7 screws from the board
Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
Inspect all electrolytic capacitors on the power supply board and replace any that are bulging or leaking.
On my board there were 2ea 2200uf capacitors that were bulging.
Remove the old capacitors ensuring you don't overheat or damage the copper pads/tracks on the circuit board
In my case I also replaced the 1000uF capacitor
18 の人々がこのガイドを完成させました。
13 件のコメント
Hello, I have the blinking red lights when I try to turn on my Samsung lcd tv. I checked the capacitors and they seem to be fine except a smaller 16v 12mm capacitor is slightly bulging(not broken or leaking yet). Would that be enough to cause this? And should I just replace it?
Thank you!
Hi I have Samsung 32h5100 tv I have problem that horizontal lines appear half an hour after the tv is on later vertical lines later above half white mask later picture and sound off then I turn off the tv. After few hours I tune tv on it appears normally gradually problem repeat again. What will be the problem and what I have to do Please help me……
Do it matter what type of power card to use??
pearsonm22 - 返信
Do it matter what power card to use on my haier 55 in flat screen tv??
pearsonm22 - 返信
When i plug my haier 55 in tv up . the red light comes on. When i push the power on the red light goes off. But the tv dont come on still ???
pearsonm22 - 返信
