メインコンテンツにスキップ
Repairing Samsung LA40R81BD 40in LCD TV Power Supply (clicking Relay Symptom)
必要な工具と部品
  1. Repairing Samsung LA40R81BD 40in LCD TV Power Supply (clicking Relay Symptom), Rear Cover: 手順 1、 1の画像 1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
  2. Repairing Samsung LA40R81BD 40in LCD TV Power Supply (clicking Relay Symptom), Power Supply Board: 手順 2、 1の画像 1
    • Remove the 7 connectors from the board
    • Remove the 7 screws from the board
    • Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
  3. Repairing Samsung LA40R81BD 40in LCD TV Power Supply (clicking Relay Symptom), Repairing Samsung LA40R81BD 40in LCD TV Power Supply (clicking Relay Symptom): 手順 3、 1の画像 1
    • Inspect all electrolytic capacitors on the power supply board and replace any that are bulging or leaking.
    • On my board there were 2ea 2200uf capacitors that were bulging.
    • Remove the old capacitors ensuring you don't overheat or damage the copper pads/tracks on the circuit board
    • Take care to ensure you install the new capacitors correctly. They are polarity sensitive and the board and capacitors will be clearly marked which way they should be inserted.
    • You may want to check and replace any adjacent capacitors that are rated 10V as these seem to be the ones likely to fail.
    • In my case I also replaced the 1000uF capacitor
    • If you have a different model TV the layout of the power supply board may be different however the faulty capacitors should be easily identifiable.
    • If replacing the capacitors does not resolve your symptoms you may need to replace the eprom on the main board as it can be corrupted or damaged by the power cycling
終わりに
18 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Richdave
メンバー登録日: 04/09/10
32,051 ポイント
30のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,521のガイドは作成済み
13 件のコメント
would it be possible to replace the 2200uF capacitors with a larger size? this issue has occurred already on this TV and again on another of the same model. Thanks.
Callum - 返信
Higher voltage rated and better quality caps are what you need, don't change the value of teh capacitor though.
Richdave -
Hi would like to ask, if i do open up and check i find no capacitor is bloat or faulty. will there be other parts that will cause the clicking Relay Symptom? Appreciate it if anyone can help me on it. thanks
preseanis - 返信
Hello, I have the blinking red lights when I try to turn on my Samsung lcd tv. I checked the capacitors and they seem to be fine except a smaller 16v 12mm capacitor is slightly bulging(not broken or leaking yet). Would that be enough to cause this? And should I just replace it?
Thank you!
Kyle Durksen - 返信
Richdave, do you know if any suppliers have the EEPROM still? The 2 x 2200uf cap were bulging on mine but after replacement the power cycling continued. All the 5 to 13V rails are there, no HV out of other side.
niium - 返信
Hi my name is Charles i have Samsung LA40R81B model, when i on it it works fine suddenly back light cuts off but picture will be on if off & on back light will on & offs again can you help me in troubleshooting it
Charles S - 返信
Hi I have Samsung 32h5100 tv I have problem that horizontal lines appear half an hour after the tv is on later vertical lines later above half white mask later picture and sound off then I turn off the tv. After few hours I tune tv on it appears normally gradually problem repeat again. What will be the problem and what I have to do Please help me……
Bharat kumar Doddi - 返信
Were is the relay at
Susan Cox - 返信
i have 32 led tv samsung .. in that power supply dc out put at 13 v two parlel diodes are there the diodes are very heat & short. Within 5 minits . Picture ok audio ok but diodes short within 5 minits diodes no. LT 5143
sasikala - 返信
I have a 32-inch TV set that buzzes when I work. I bought a power board from Abctay and changed it into it.
Lambert - 返信
Do it matter what type of power card to use??
pearsonm22 - 返信
Do it matter what power card to use on my haier 55 in flat screen tv??
pearsonm22 - 返信
When i plug my haier 55 in tv up . the red light comes on. When i push the power on the red light goes off. But the tv dont come on still ???
pearsonm22 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 32
今までの合計 49,713
