メインコンテンツにスキップ
Repairing Samsung Chromebook Series 3 Track Pad
必要な工具と部品
  1. Repairing Samsung Chromebook Series 3 Track Pad, Loosening the adhesive: 手順 1、 1の画像 1
    • Place the iOpener or another type of heating bag, in the microwave for 1 minute.
    • Remove and press on the track pad for 1 -2 minutes as to loosen the adhesive.
  2. Repairing Samsung Chromebook Series 3 Track Pad, Removing the track pad cover: 手順 2、 1の画像 1
    • Apply pressure to the the bottom of the Chromebook under the track pad.
    • Using a fingernail, or other small prying tool, separate the plastic covering from the track pad board.
  3. Repairing Samsung Chromebook Series 3 Track Pad, Verifying the track pad clicks: 手順 3、 1の画像 1
    • Completely remove the cover from the track pad board.
    • Press on the track pad board in order to verify that it still clicks.
  4. Repairing Samsung Chromebook Series 3 Track Pad, Reapplying the track pad: 手順 4、 1の画像 1
    • Reapply the cover to the track pad board starting from the top.
    • Be sure to leave a slight gap between the cover and casing on all sides when reapplying.
  5. Repairing Samsung Chromebook Series 3 Track Pad, Finishing up: 手順 5、 1の画像 1
    • Finish applying the track pad cover and firmly press it to the track pad board.
    • Ensure that the track pad still clicks, if it does not, remove the cover, adjust the positioning, and reapply.
    • *The track pad may not behave properly until the adhesive is completely cooled and the cover completely set.
終わりに
10 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
richard
メンバー登録日: 11/24/14
305 ポイント
1ガイドが承認済み
7 件のコメント
This works great. I do not have the iOpener heating pad, but I do have a heat gun. I set it to low setting and used a stainless spunger I had to pry off the plastic film that is silver in color and repositioned it. thank you for this as we have many touchpads sticking/hard to press
Ken S - 返信
It works! Thanks for the great instructions and simple solution!
Maureen - 返信
I did it, awkwardly using an excessively large gel heating pad to loosen the cover, and then prying it off.
I think the best advice in replacing the cover is to position the edge of the cover flush with the edge of the surrounding casing that is near the keyboard, leaving a slight but visible gap between the cover and the edge of the surrounding casing that is away from the keyboard. The latter gap ensures that the casing won't prevent the cover from moving and clicking the button underneath. (I don't think any gap at the edge near the keyboard is necessary, since the button that has to be clicked is far from that edge.)
Roger Aarons - 返信
Worked like a charm! Thanks!!
showdaze - 返信
I just realized you don't need to actually remove the plastic track pad cover. Once it is heated you can just push it towards the keys. That will free it up enough to "click" again. I also use a small piece of tape to hold it in place while the glue dries. I tape it so that it is putting pressure towards the keys.
showdaze - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 14,077
