メインコンテンツにスキップ
Repairing Quasar Microwave Door Handle
必要な工具と部品
  1. Repairing Quasar Microwave Door Handle, Disassembling Quasar Microwave Outer Cover: 手順 1、 1の画像 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Door Handle: 手順 2、 2の画像 1 Repairing Quasar Microwave Door Handle: 手順 2、 2の画像 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Door Handle: 手順 3、 2の画像 1 Repairing Quasar Microwave Door Handle: 手順 3、 2の画像 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Door Handle: 手順 4、 3の画像 1 Repairing Quasar Microwave Door Handle: 手順 4、 3の画像 2 Repairing Quasar Microwave Door Handle: 手順 4、 3の画像 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: 手順 5、 2の画像 1 Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: 手順 5、 2の画像 2
    • Observe the lever mechanism found just behind the door handle, inside the microwave.
    • The plastic lever should be above the metal lever. If the metal lever is above the plastic lever, this is why the door will not open.
    • In this picture, the metal part is ABOVE the white plastic part. The white part needs to be lifted to open the door so when the door lever is pressed, the metal part rises, and the plastic part stays in place.
  6. Repairing Quasar Microwave Door Handle: 手順 6、 3の画像 1 Repairing Quasar Microwave Door Handle: 手順 6、 3の画像 2 Repairing Quasar Microwave Door Handle: 手順 6、 3の画像 3
    • Lift up on the outside lever.
    • Push up on the white plastic piece.
    • Push metal bar down, snapping the white plastic piece above it.
  7. Repairing Quasar Microwave Door Handle: 手順 7、 2の画像 1 Repairing Quasar Microwave Door Handle: 手順 7、 2の画像 2
    • This is how the fixed mechanism should look.
    • Press the button and enjoy your newly fixed door!
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Samuel
メンバー登録日: 09/26/12
142 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S2G12
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 2,036
