メインコンテンツにスキップ
Repairing Polaroid Sun 600 LMS Gear Train
必要な工具と部品
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: 手順 1、 2の画像 1 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: 手順 1、 2の画像 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: 手順 2、 1の画像 1
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: 手順 3、 1の画像 1
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
終わりに
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Matthew Lessig
メンバー登録日: 01/20/10
63 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-18, Maness Winter 2010 Cal Poly, Team 3-18, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S3G18
4 メンバー
4のガイドは作成済み
3 件のコメント
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - 返信
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 36
今までの合計 9,061
