はじめに
The parabolic solar cooker can receive damage to the reflective dish. The replacement reflective foil peals off like a sticker, allowing a simple and easy fix. The parabolic solar cooker needs to have full efficiency of a parabolic reflective dish in order to capture the energy from the sun at the focal point.
  1. Use the scissors to cut off a piece of the reflective foil. The cut piece should match the size of the repair area.
    • Use the scissors to cut off a piece of the reflective foil.
    • The cut piece should match the size of the repair area.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Peel the reflective foil off of the cut piece. Peel the reflective foil off of the cut piece.
    • Peel the reflective foil off of the cut piece.
  4. Place the cut piece of reflective foil over damaged area. Press down to seal the adhesive to the dish.
    • Place the cut piece of reflective foil over damaged area.
    • Press down to seal the adhesive to the dish.
まとめ
ある他の人がこのガイドを完成しました。
Griffin Paul
メンバー登録日: 2013年10月18日
385 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S4G30
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 358
