この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This is a quick guide on replacing a faulty joystick on an N64. If you have a controller with a wobbly joystick, this is the way to resolve your issue.
This can also be considered a mod if you are upgrading the joystick to a redesigned replacement. Upgrading is recommended because the Nintendo 64 has a poorly designed joystick that is prone to breaking and because the redesigned joystick has better control.
必要な工具と部品
Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
Remove the 2 #00 Phillips screws from the expansion slot
Remove the rear housing and set aside.
Test out your controller! It should be feeling like new.
33 の人々がこのガイドを完成させました。
2 件のコメント
If you don't line up the z button accurately it can be tricky getting the case back on.
