はじめに
In the event that the lens cover is not functioning properly, either permanently opened or closed, it is necessary to align it properly on its spring arm.
必要な工具と部品
Place the internal electronics face-up. Look at the side with the flash turned towards you.
The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
Reassemble the casing by reversing steps 1 and 2.
コメント 1 件
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
