はじめに
The scanner unit allows the user to scan documents onto their computer and/or copy and print original document.
ツール
パーツ
パーツは必要ありません。
  1. Locate data USB cable.
    • Locate data USB cable.
  2. Locate the end of the cable that plugs into the printer.
    • Locate the end of the cable that plugs into the printer.
    • Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
    • Locate the USB end of the cable. Insert that end into your computer.
    • Turn wireless connection on your computer off and on. Sometimes doing this step is needed to have a connection.
    • Check the network to make sure the computer and printer are connected to the same network.
    • Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off.
    • Move the printer close to the router to ensure a strong connection.
    • Make sure the transparent cover is clean. If not, wipe the glass screen with a polishing cloth. If there is still debris on the glass, try spraying it with a cleaning solution and wiping it again.
    • If the print not is not clear, make sure the original document is flat on the glass. If the print out is still not clear, try finding a clearer version of your original document.
    • If above steps do not solve the problem, try re-installing the drive for the printer.
まとめ
Once your connection is set and that the screen is clear of any debris, you should be able to scan, copy and print documents.
ある他の人がこのガイドを完成しました。
Raymond
メンバー登録日: 2013年01月15日
42 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G38
4 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 802
