メインコンテンツにスキップ
Repairing LG 17LX1R LCD Television Power board
必要な工具と部品
  1. Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 手順 1、 3の画像 1 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 手順 1、 3の画像 2 Repairing LG 17LX1R LCD Television Power board, Repairing LG 17LX1R LCD Television Power board: 手順 1、 3の画像 3
    • This is the LG 17LX1R that will no longer turn on.
    • Remove the cover from the stand by.
    • Press down on the two tabs. The cover should come off easily.
    • Remove the four screws that hold the stand assembly to the chassis.
  2. Repairing LG 17LX1R LCD Television Power board: 手順 2、 3の画像 1 Repairing LG 17LX1R LCD Television Power board: 手順 2、 3の画像 2 Repairing LG 17LX1R LCD Television Power board: 手順 2、 3の画像 3
    • Remove the four Phillips head screws that attach the stand to the chassis.
    • Remove the eight Phillips screws that hold the back to the chassis. Once the screws are removed, the back will simply snap off.
    • Remove the metal shield. It is fastened with six Phillips screws.
  3. Repairing LG 17LX1R LCD Television Power board: 手順 3、 3の画像 1 Repairing LG 17LX1R LCD Television Power board: 手順 3、 3の画像 2 Repairing LG 17LX1R LCD Television Power board: 手順 3、 3の画像 3
    • After the shield is removed, the power board and the main board are visible.
    • Power Board
    • Main Board
    • Fuse
    • Check all capacitors for blown tops and/or leakage.
    • Thoroughly inspect the boards. Brown discoloration around Diode D102 is evidence of a short circuit, possibly a blown component.
    • Disconnect all connectors from the power board
    • Remove the four screws that mount the power board to the chassis.
  4. Repairing LG 17LX1R LCD Television Power board: 手順 4、 3の画像 1 Repairing LG 17LX1R LCD Television Power board: 手順 4、 3の画像 2 Repairing LG 17LX1R LCD Television Power board: 手順 4、 3の画像 3
    • These are the chassis with the power board removed.
    • Discoloration of the back side of the power board is a sign of a faulty diode.
    • Unsolder the diode from the power board.
    • Replacement diode
  5. Repairing LG 17LX1R LCD Television Power board: 手順 5、 3の画像 1 Repairing LG 17LX1R LCD Television Power board: 手順 5、 3の画像 2 Repairing LG 17LX1R LCD Television Power board: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Here is the removed diode. Description on the diode reads LT526 IN4007.
    • Solder the new diode onto the power board. Use a pair of tweezers or hemostat to hold the diode in place while soldering.
    • Once the diode is replaced, clean the board with isopropyl alcohol to get rid of any debris or old flux.
  6. Repairing LG 17LX1R LCD Television Power board: 手順 6、 1の画像 1
    • Device powers on and has audio and video after the repair.
終わりに
38 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
oldturkey03
メンバー登録日: 09/29/10
812,920 ポイント
119のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
45 メンバー
702のガイドは作成済み
3 件のコメント
Very nice good job
Bhullana - 返信
good job my frend
youcef - 返信
great idea thats perfect
Joseph Mwangome - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 48
今までの合計 11,422
