はじめに
Does your toast not stay down when you press the lever down? Does your toaster not even heat up when pressed down? Use this guide to repair the lever to get your toaster in working condition again.
必要な工具と部品
Next, remove the crumb tray from the bottom slot and set it aside.
Pull the toaster lever cover straight off.
Place the newly bent paperclip onto plastic lever weaving it through the divots. Make sure that when the main spring comes down it engages the paperclip to push the lever down.
Use an adhesive to bond the paperclip to the plastic lever. A plastic welding adhesive such as JB weld will work best but super glue or even a hot glue gun will work as well. As long as the paperclip stays glued on, the toaster will function fine. Make sure to fully cover the paperclip with the adhesive.
To reassemble your device, follow steps 1-5 in reverse order.
ある他の人がこのガイドを完成しました。
