メインコンテンツにスキップ
Repairing Hungry Cat Savings Bank Gear
必要な工具と部品
  1. Repairing Hungry Cat Savings Bank Gear, Repairing Hungry Cat Savings Bank Gear: 手順 1、 1の画像 1
    • Turn the Hungry Cat Savings Bank off.
    • Using a coin, remove the cap covering the change storage.
    • Use a standard Phillips screwdriver #0 to remove the screw holding the battery cover in place.
  2. Repairing Hungry Cat Savings Bank Gear: 手順 2、 1の画像 1
    • Empty all change from the Hungry Cat Savings Bank, or it will drive you bonkers during repair.
  3. Repairing Hungry Cat Savings Bank Gear: 手順 3、 1の画像 1
    • Remove the battery cover and batteries.
  4. Repairing Hungry Cat Savings Bank Gear: 手順 4、 1の画像 1
    • Remove the four screws holding the cover in place. You'll need a traditional Phillips screwdriver, not a screwdriver set, to reach fully into the wells.
  5. Repairing Hungry Cat Savings Bank Gear: 手順 5、 1の画像 1
    • Turn over savings bank and slide case up. You might need to grab the base to pull it apart.
  6. Repairing Hungry Cat Savings Bank Gear: 手順 6、 1の画像 1
    • Locate the jam. You might need to temporarily put in the batteries to activate the arm, so you can find the jam.
  7. Repairing Hungry Cat Savings Bank Gear: 手順 7、 1の画像 1
    この手順で使用する道具:
    購入する
    • Remove the coin using a set of tweezers.
    • Reassemble the device and enjoy your working Hungry Cat Savings Bank!
終わりに
To reassemble your device, follow these instructions in reverse order. Make sure to remove the batteries before reassembling.
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jeannie Crowley
メンバー登録日: 07/14/15
459 ポイント
2のガイドは作成済み
チーム
Ethical Culture Fieldston School Ethical Culture Fieldston School人のメンバー
Business
3 メンバー
2のガイドは作成済み
6 件のコメント
Hi, my motor burned out, where could I get a replacement?
Krill - 返信
My one will not stop once it has grabbed a coin , the paw keeps coming out and it has to be turned off at the switch. And he doesn't meow anymore.
michael.tulley - 返信
I don’t have my box in front of me, but it sounds like the tray isn’t returning to the rest position fully. When you disassemble it, is there anything preventing the tray (where you put the quarter) from smoothly returning to rest position?
Jeannie Crowley -
How to you repair the Godzilla bank? Bought one yesterday and it completely stopped working?
divineangel1952 - 返信
Is there any sound at all coming from the bank or is it completely silent when you press the button?
Jeannie Crowley -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 58
今までの合計 5,987
