必要な工具と部品
Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
Start at the top, and work clockwise, being careful not to break the clips.
There are, 1, 3, 2, and 3 clips on each side, respectively.
After the clips are disengaged, there are no cables holding the back panel in place.
Use your spudger to release the jaw clip holding the Optical Track Pad cable to the logic board.
Remove Optical Track Pad from logic board.
Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
4 の人々がこのガイドを完成させました。
