メインコンテンツにスキップ
Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip
必要な工具と部品
  1. Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip, Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip: 手順 1、 1の画像 1
    • Cut away the old (likely disintegrated) strip from the blade using a knife. Get a waterproof bandaid and cut 4 or 5 thin strips from the sticky part and layer them to make a new strip. Use the smooth-type bandage; not flexible fabric. Then sharpen by stropping on blue jeans. Voila! Shaves just like new. Blow dry after shaving to prevent rust.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
PartsIn
メンバー登録日: 12/31/12
247 ポイント
1ガイドが承認済み
4 件のコメント
This is great! I'll have to try it. I'd love more information on how to sharpen the blades on blue jeans. How much stroking does it take to sharpen them? How do you tell when it's sharp enough?
Kyle Wiens - 返信
Hey it takes about 15 to 20 strokes each way ( up and down) to maintain it. And 150 to 200 each way to re sharpen it. And when you can take off most of the hair on your arm in one pass its sharp enough
chase morris -
Yeah, a guide on "stopping" a razor would be great!
Daniel Beardsley - 返信
Hi, I have a sterling silver razor handle with. Gillette blade housing. The housing is worn and does no longer supports the blade. Can I get a replacement top and switch it out with the broken one? Thanks Kevin
Kevin Locke - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 23
今までの合計 11,290
