はじめに
Stalled printer for error 0xF2 or 0xF3
This error happens when there are some problems with the encoder when the roller tries to move paper.
必要なもの
Remove the paper tray
Remove the paper cassette
Remove the ink tanks.
Clean the right encoder very gently with a dry tissue or a soft brush.
16 の人々がこのガイドを完成させました。
14 件のコメント
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
Error descriptions I found here - http://www.fatalerrors.info/
muito obrigado pela ajuda
You are awesome! It helped me! Thanks very much!
Hi
I keep getting on an Epson B-500DN printer error restart printer with the paper and ink led blinking orange.
Disassemble the printer made a full cleaning (all encoding wheels too) and keep getting this error, the printer goes until ready, then as soon as it says printing it shows the error.
anyone ???
OMG.
I had error oxF3.
I was set to bin this ace printer, I just googled the error code and bam this guide came up. This was awesome, I only found a little dirt on the step 12 clear plastic disc, nothing visible on step 13. Put the cartridges back in, maintenance tank paper tray and hooked up the power and network cable, and covered the 2 switches with tape. then OMG it worked. Now need to work out which screw goes where and reassemble.
OK. Seguito con semplicità e Risolto il Problema. Adesso funziona. OK Thank you
Foto Diego - 返信
What about Erro code 0xF3 in Epson WF7610
ABEL MLIGA - 返信
Yes what about the WF7610 error code 0xF3?!
I have Epson XP 710 which shows an error code 0×4f what can i do for it. When i turned it on it's starts well with Epson logo but there's a sound of running the gears in fast speed for a few seconds after this it's showing the error just after pooping up the menu screen no head movement. Kindly forward me with possible assistance
Constantly gives 0xF4. If you move the head to the center, when it is turned on, it goes to the left, then goes to its place and when Parking the engine PF PID (left) twitches a little, and the scoreboard error 0xF4. In printer all cleaned up, blew. Cartridges took out, got a diaper. Before that, it was so that it prints, then outputs 0xF4 and sometimes 0xF1. What to do?
Works very good. The photos for the right sight could be better, but when you know how it looks on the left its possible to find.
Ralf Sagorny
