はじめに
This guide will show how to replace the speaker on the Casio camera
パーツ
パーツは必要ありません。
  1. Remove the four screws on the side with the speaker
    • Remove the four screws on the side with the speaker
  2. Remove the four screws from the bottom of the camera.
    • Remove the four screws from the bottom of the camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly
    • Remove the four screws on the side opposite of the speaker.
    • Pull apart the bottom casing.
    • Remove ribbon from the rear casing.
    • Set aside rear casing.
    • Use tweezers or prongs to pry the LCD screen off from the opening.
    • Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
    • Lift up the LCD screen, slowly move it to the other side.
    • Pry off the LCD casing which is taped on to the frame.
    • Flip open the connector holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
    • Pull apart the front casing.
    • Remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
    • On the front of the camera near the flash flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
    • Carefully remove the L shaped frame from the camera
    • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
    • Pop the frame off the bumps and tabs.
    • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
    • The blue box is the speaker
    • Remove the speaker with tweezers
まとめ
Christian
メンバー登録日: 2011年01月28日
320 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G38
4 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,515
