必要な工具と部品
To repair a short in the wires, the head band has two screws, just above the headphones cups.
After removing the two small screws, try closing the headband to it's shortest position. The outer panel will pop out toward the bottom edge.
You can then slide the panel out from under the collar. The collar may slide out of place while working, but can easily be slid back during re-assembly.
5 の人々がこのガイドを完成させました。
