メインコンテンツにスキップ
Repairing Black and Decker BL3000S Power Cord
必要な工具と部品
  1. Repairing Black and Decker BL3000S Power Cord, Blender Base: 手順 1、 2の画像 1 Repairing Black and Decker BL3000S Power Cord, Blender Base: 手順 1、 2の画像 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Repairing Black and Decker BL3000S Power Cord: 手順 2、 1の画像 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Repairing Black and Decker BL3000S Power Cord: 手順 3、 2の画像 1 Repairing Black and Decker BL3000S Power Cord: 手順 3、 2の画像 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Repairing Black and Decker BL3000S Power Cord: 手順 4、 1の画像 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Repairing Black and Decker BL3000S Power Cord: 手順 5、 1の画像 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Repairing Black and Decker BL3000S Power Cord, Power Cord: 手順 6、 1の画像 1
    • Tug on wires in the marked locations to make sure they are secure.
    • If the wire stays still, the connection is secure.
    • If you still have problems with the blender, it is probably a problem with the motor. Since the motor is irreplaceable, you will have to order a new blender.
  7. Repairing Black and Decker BL3000S Power Cord: 手順 7、 1の画像 1
    • If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
    • If you don't know how to solder, here is a link to show you how. http://www.aaroncake.net/electronics/sol...
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Elmer Pres Urbano
メンバー登録日: 10/05/12
148 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G34
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 36
今までの合計 3,892
