メインコンテンツにスキップ
Repairing Billion Router BiPAC 7404VNPX VOIP
必要な工具と部品
  1. Repairing Billion Router BiPAC 7404VNPX VOIP, Repairing Billion Router BiPAC 7404VNPX VOIP: 手順 1、 1の画像 1
    • Turning the Router over you find 4 rubber feet hiding 4 Philips head screws.
    • Remove the screws and turn the router back upright.
    • The top of the case should now lift off.
  2. Repairing Billion Router BiPAC 7404VNPX VOIP: 手順 2、 2の画像 1 Repairing Billion Router BiPAC 7404VNPX VOIP: 手順 2、 2の画像 2
    • The C928 Capacitor 100uF 25v is the one talked about in the forum mentioned in the intro.
    • While I was checking the solder side of the board I noticed there was a bad solder joint on this cap. You cant see it at this resolution though.
    • While checking the state of the other caps on the board I noticed that this one 1000uF 10v was also showing signs of heat stress.
    • Both capacitors were replaced.
    • You can see the new caps in position on the right.
    • For the princely sum AU $1.20 in parts, 20 mins setting up, 5 mins to fix, 5 mins to put it all away I have saved myself aprox $200 for a new VOIP router :)
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
mikejgrantham
メンバー登録日: 05/29/12
146 ポイント
1ガイドが承認済み
2 件のコメント
Champion!
Thanks for this.
$1.30 in parts saved me going out buying a new VOIP adapter.
Nick Gustafsson - 返信
No worries, Glad it helped :)
mikejgrantham - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 20
今までの合計 1,590
