このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
In order to make some room to work, it's necessary to pull some wire off. Pinch the wire inside the housing with two fingers and (again) gently pull it some 2-3 inches. It's not easy, but it will come out, little by little. A small amount of silicone spray in the metal ring, in the back of the housing (where the wire comes in) may help.
7 の人々がこのガイドを完成させました。
7 件のコメント
how did you remove the front housing?
Marcos, there's no "front housing". The whole thing is composed of two parts: the speaker and the polycarbonate housing. The speaker is attached to the housing via 3 screws (step 1 in this guide)
But maybe you're talking about a grille some of these speakers have, over the driver, that can be easily removed - just pull it out.
Hope this helps.
martins, the speaker is composed of 3 parts.
1- the acrylic ball;
2- the inner housing that moves out when you unscrew the silver cover at the back
3- the speaker which attaches to the inner housing
Jayme, I haven't noticed that. Maybe it would make step 3 easier.
Thanks for the heads up!
Martins Jr - 返信
