この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Straightening the rim requires a lot of time and patience in order to get it just right. This is a fix that can be done fairly easily, but if you don't feel comfortable straightening your own rim after reading through the guide, it is probably best to take it to a bike shop in order to prevent further damaging your rim.
必要な工具と部品
Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
Slightly loosen the valve bolt counterclockwise with your thumb and index finger.
Deflate the tire by pressing down the air valve tip with your finger. Use as much pressure as needed to hear the air flowing out of the tube.
Hold the tire lever firmly in your hands and look for the boundary between the tire and the wheel rim. Apply great force to the lever until you pry the rim and the tire apart.
With the tip of the lever inserted between the rim and the tire, rotate the lever 90° counterclockwise and fix the lever to the metal spokes using the arrow shaped slot located on the top of the lever.
Once you have the tire removed from the rim, place the rim on the truing stand and tighten the stand on the axle using the knob on the side of the stand to make sure the rim is secured on the stand.
Raise the calipers on the stand so they are the same height as the rim. You can adjust the height of the calipers using knob on the base of the stand.
Loosen the spokes on the side of the tire slightly using the spoke wrench. Adjust the spoke directly where the bend was along with 2 or 3 spokes on each side of it. Try to keep each adjustment around 1/4 to 1/2 of a turn to avoid tightening or loosening a spoke too much.
Go back and tighten the spokes that connect to the opposite side of the tire using the same technique.
ある他の人がこのガイドを完成しました。
